SU2020的D5实时同步插件报错加载不上
报错内容:
载入文件 C:/Users/Enen/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb 时出错
Error: #<LoadError: cannot load such file – set>
C:/Users/Enen/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:5:in require' C:/Users/Enen/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:5:in <top (required)>’
D:/Enen Office Software/草图大师2020/Tools/extensions.rb:197:in require' D:/Enen Office Software/草图大师2020/Tools/extensions.rb:197:in load’
C:/Users/Enen/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/d5_converter.rb:49:in register_extension' C:/Users/Enen/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/d5_converter.rb:49:in module:D5Converter
C:/Users/Enen/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/d5_converter.rb:29:in <top (required)>' Error: #<LoadError: cannot load such file -- fileutils> c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/main.rbe:4:in require’
c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/main.rbe:4:in <main>' c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:61:in eval’
c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:61:in require' c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:61:in block in load_source_files’
c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:61:in each' c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:61:in load_source_files’
c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:66:in <module:TrimbleConnect>' c:/users/enen/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/su_trimble_connect/boot.rbe:11:in
怎么解决
您好,尝试不要把sketchup解压在中文路径下…换个英文路径再试一下
特意建了英文文件夹,没想到一个不留神安装在了“草图大师”下面 :sweat_smile:
