- 问题现象:D5总是闪退,没用几下就闪退,半个小时打开d5都超过7、8次了
WIN10
求解决,谢谢
文件日志:
Log file open, 12/08/23 23:52:03
LogDXGIBridge: DXGIBridge::FDXGIDefaultFunctions::FDXGIDefaultFunctions Enter
LogDXGIBridge: CreateDXGIFactory2FnPtr = 00007FF8EA76E580
LogDXGIBridge: DXGIGetDebugInterface1FnPtr = 00007FF8EA7AB850
LogDXGIBridge: DXGIBridge::FDXGIDefaultFunctions::FDXGIDefaultFunctions Leave
LogConsoleResponse: Display: Failed to find resolution value strings in scalability ini. Falling back to default.
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_9/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_9/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_9/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_9/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_8/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_8/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_8/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_8/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_7/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_7/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_7/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_7/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_6/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_6/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_6/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_6/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_5/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_5/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_5/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_5/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_4/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_4/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_4/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_4/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_3/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_3/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_3/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_3/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_29/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_29/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_29/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_29/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_28/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_28/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_28/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_28/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_27/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_27/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_27/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_27/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_26/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_26/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_26/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_26/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_25/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_25/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_25/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_25/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_24/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_24/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_24/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_24/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_23/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_23/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_23/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_23/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_22/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_22/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_22/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_22/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_21/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_21/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_21/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_21/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_20/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_20/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_20/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_20/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_2/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_2/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_2/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_2/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_19/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_19/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_19/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_19/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_18/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_18/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_18/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_18/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_17/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_17/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_17/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_17/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_16/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_16/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_16/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_16/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_15/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_15/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_15/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_15/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_13/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_13/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_13/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_13/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_12/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_12/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_12/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_12/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_11/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_11/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_11/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_11/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_10/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_10/1.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/m2/Base_10/1.pak’, mount point: ‘…/…/…/d5_immerse/Content/MatLib2/Base/Base/Base_10/’
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/m2/Base_1/1.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/m2/Base_1/1.pak.
LogPakFile: Warning: Failed to mount pak “…/…/…/d5_immerse/Content/Paks/m2/Base_1/1.pak”, pak is invalid.
LogPakFile: Display: Found Pak file …/…/…/d5_immerse/Content/Paks/d5_immerse-Windows.pak attempting to mount.
LogPakFile: Display: Mounting pak file …/…/…/d5_immerse/Content/Paks/d5_immerse-Windows.pak.
LogPakFile: Display: Mounted Pak file ‘…/…/…/d5_immerse/Content/Paks/d5_immerse-Windows.pak’, mount point: ‘…/…/…/’
LogPlatformFile: Not using cached read wrapper
LogICUInternationalization: ICU TimeZone Detection - Raw Offset: +8:00, Platform Override: ‘’
LogInit: Session CrashGUID >====================================================
Session CrashGUID > UECC-Windows-C54E1EBC4A7B1873B0B6D79982F5AA2A
LogPluginManager: Mounting Engine plugin Paper2D
LogPluginManager: Mounting Engine plugin AISupport
LogPluginManager: Mounting Engine plugin EnvironmentQueryEditor
LogPluginManager: Mounting Engine plugin ControlRig
LogPluginManager: Mounting Engine plugin ControlRigSpline
LogPluginManager: Mounting Engine plugin IKRig
LogPluginManager: Mounting Engine plugin Bridge
LogPluginManager: Mounting Engine plugin CameraShakePreviewer
LogPluginManager: Mounting Engine plugin GameplayCameras
LogPluginManager: Mounting Engine plugin OodleNetwork
LogPluginManager: Mounting Engine plugin AnimationSharing
LogPluginManager: Mounting Engine plugin PluginUtils
LogPluginManager: Mounting Engine plugin AssetManagerEditor
LogPluginManager: Mounting Engine plugin BlueprintMaterialTextureNodes
LogPluginManager: Mounting Engine plugin EditorScriptingUtilities
LogPluginManager: Mounting Engine plugin FacialAnimation
LogPluginManager: Mounting Engine plugin GeometryMode
LogPluginManager: Mounting Engine plugin SequencerAnimTools
LogPluginManager: Mounting Engine plugin SpeedTreeImporter
LogPluginManager: Mounting Engine plugin VariantManagerContent
LogPluginManager: Mounting Engine plugin AutomationUtils
LogPluginManager: Mounting Engine plugin BackChannel
LogPluginManager: Mounting Engine plugin ChaosCloth
LogPluginManager: Mounting Engine plugin ChaosClothEditor
LogPluginManager: Mounting Engine plugin ChaosEditor
LogPluginManager: Mounting Engine plugin ChaosNiagara
LogPluginManager: Mounting Engine plugin ChaosSolverPlugin
LogPluginManager: Mounting Engine plugin FullBodyIK
LogPluginManager: Mounting Engine plugin GeometryCollectionPlugin
LogPluginManager: Mounting Engine plugin Landmass
LogPluginManager: Mounting Engine plugin OpenImageDenoise
LogPluginManager: Mounting Engine plugin PlatformCrypto
LogPluginManager: Mounting Engine plugin PythonScriptPlugin
LogPluginManager: Mounting Engine plugin Volumetrics
LogPluginManager: Mounting Engine plugin Niagara
LogPluginManager: Mounting Engine plugin NiagaraFluids
LogPluginManager: Mounting Engine plugin ImgMedia
LogPluginManager: Mounting Engine plugin MediaCompositing
LogPluginManager: Mounting Engine plugin WebMMedia
LogPluginManager: Mounting Engine plugin WmfMedia
LogPluginManager: Mounting Engine plugin MeshPainting
LogPluginManager: Mounting Engine plugin TcpMessaging
LogPluginManager: Mounting Engine plugin UdpMessaging
LogPluginManager: Mounting Engine plugin ActorSequence
LogPluginManager: Mounting Engine plugin LevelSequenceEditor
LogPluginManager: Mounting Engine plugin SequencerScripting
LogPluginManager: Mounting Engine plugin TemplateSequence
LogPluginManager: Mounting Engine plugin OnlineServices
LogPluginManager: Mounting Engine plugin OnlineBase
LogPluginManager: Mounting Engine plugin OnlineSubsystem
LogPluginManager: Mounting Engine plugin OnlineSubsystemUtils
LogPluginManager: Mounting Engine plugin LauncherChunkInstaller
LogPluginManager: Mounting Engine plugin ActorLayerUtilities
LogPluginManager: Mounting Engine plugin AndroidFileServer
LogPluginManager: Mounting Engine plugin AndroidPermission
LogPluginManager: Mounting Engine plugin AppleImageUtils
LogPluginManager: Mounting Engine plugin ArchVisCharacter
LogPluginManager: Mounting Engine plugin AssetTags
LogPluginManager: Mounting Engine plugin AudioCapture
LogPluginManager: Mounting Engine plugin AudioSynesthesia
LogPluginManager: Mounting Engine plugin CableComponent
LogPluginManager: Mounting Engine plugin ChunkDownloader
LogPluginManager: Mounting Engine plugin CustomMeshComponent
LogPluginManager: Mounting Engine plugin ExampleDeviceProfileSelector
LogPluginManager: Mounting Engine plugin GeometryCache
LogPluginManager: Mounting Engine plugin GeometryProcessing
LogPluginManager: Mounting Engine plugin GooglePAD
LogPluginManager: Mounting Engine plugin HairStrands
LogPluginManager: Mounting Engine plugin XeSS
LogPluginManager: Mounting Engine plugin LocationServicesBPLibrary
LogPluginManager: Mounting Engine plugin MobilePatchingUtils
LogPluginManager: Mounting Engine plugin DLSS
LogPluginManager: Mounting Engine plugin NRD
LogPluginManager: Mounting Engine plugin RTXGI
LogPluginManager: Mounting Engine plugin OculusVR
LogPluginManager: Mounting Engine plugin OpenCV
LogPluginManager: Mounting Engine plugin OpenXR
LogPluginManager: Mounting Engine plugin ProceduralMeshComponent
LogPluginManager: Mounting Engine plugin PropertyAccessEditor
LogPluginManager: Mounting Engine plugin ResonanceAudio
LogPluginManager: Mounting Engine plugin RuntimePhysXCooking
LogPluginManager: Mounting Engine plugin SignificanceManager
LogPluginManager: Mounting Engine plugin SoundFields
LogPluginManager: Mounting Engine plugin SteamController
LogPluginManager: Mounting Engine plugin SteamShared
LogPluginManager: Mounting Engine plugin SteamVR
LogPluginManager: Mounting Engine plugin Synthesis
LogPluginManager: Mounting Engine plugin WebMMoviePlayer
LogPluginManager: Mounting Engine plugin WindowsDeviceProfileSelector
LogPluginManager: Mounting Engine plugin WindowsMoviePlayer
LogPluginManager: Mounting Project plugin MeshSyncServer
LogPluginManager: Mounting Project plugin ProceduralVine
LogPluginManager: Mounting Project plugin RuntimeMeshComponent
LogPluginManager: Mounting Project plugin ShaderTest
LogPluginManager: Mounting Project plugin VictoryUMG
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/2D/Paper2D/Content/’ mounted to ‘/Paper2D/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Animation/ControlRig/Content/’ mounted to ‘/ControlRig/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Animation/ControlRigSpline/Content/’ mounted to ‘/ControlRigSpline/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Animation/IKRig/Content/’ mounted to ‘/IKRig/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Bridge/Content/’ mounted to ‘/Bridge/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Developer/AnimationSharing/Content/’ mounted to ‘/AnimationSharing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Editor/GeometryMode/Content/’ mounted to ‘/GeometryMode/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Editor/SpeedTreeImporter/Content/’ mounted to ‘/SpeedTreeImporter/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosClothEditor/Content/’ mounted to ‘/ChaosClothEditor/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosNiagara/Content/’ mounted to ‘/ChaosNiagara/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/ChaosSolverPlugin/Content/’ mounted to ‘/ChaosSolverPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/FullBodyIK/Content/’ mounted to ‘/FullBodyIK/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/GeometryCollectionPlugin/Content/’ mounted to ‘/GeometryCollectionPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/Landmass/Content/’ mounted to ‘/Landmass/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/PythonScriptPlugin/Content/’ mounted to ‘/PythonScriptPlugin/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Experimental/Volumetrics/Content/’ mounted to ‘/Volumetrics/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/FX/Niagara/Content/’ mounted to ‘/Niagara/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/FX/NiagaraFluids/Content/’ mounted to ‘/NiagaraFluids/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Media/MediaCompositing/Content/’ mounted to ‘/MediaCompositing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/MovieScene/SequencerScripting/Content/’ mounted to ‘/SequencerScripting/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/AudioSynesthesia/Content/’ mounted to ‘/AudioSynesthesia/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/GeometryProcessing/Content/’ mounted to ‘/GeometryProcessing/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/HairStrands/Content/’ mounted to ‘/HairStrands/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Intel/XeSS/Content/’ mounted to ‘/XeSS/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Nvidia/DLSS/Content/’ mounted to ‘/DLSS/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Nvidia/NRD/Content/’ mounted to ‘/NRD/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Nvidia/RTXGI/Content/’ mounted to ‘/RTXGI/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Oculus/OculusVR/Content/’ mounted to ‘/OculusVR/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/OpenCV/Content/’ mounted to ‘/OpenCV/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/OpenXR/Content/’ mounted to ‘/OpenXR/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/ResonanceAudio/Content/’ mounted to ‘/ResonanceAudio/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Steam/SteamVR/Content/’ mounted to ‘/SteamVR/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/…/Engine/Plugins/Runtime/Synthesis/Content/’ mounted to ‘/Synthesis/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/MeshSyncServer/Content/’ mounted to ‘/MeshSyncServer/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/ProceduralVine/Content/’ mounted to ‘/ProceduralVine/’
LogPackageName: Display: FPackageName: Mount point added: ‘…/…/Plugins/ShaderTest/Content/’ mounted to ‘/ShaderTest/’
LogOnline: Warning: OSS: TryLoadSubsystemAndSetDefault: LoadSubsystemModule([NULL]) failed
LogOnline: OSS: Failed to load any Online Subsystem Modules
LogDLSSNGXVulkanRHIPreInit: FNGXVulkanRHIPreInitModule::StartupModule Enter
LogD3D12RHI: Aftermath initialized
LogDXGIBridge: calling DXGIBridge::CreateDXGIFactory through FDXGIDefaultFunctions
LogDXGIBridge: DXGIBridge::FDXGIDefaultFunctions::CreateDXGIFactory
LogD3D12Bridge: calling D3D12Bridge::D3D12CreateDevice via FD3D12DefaultFunctions
LogD3D12Bridge: D3D12Bridge::FD3D12DefaultFunctions::D3D12CreateDevice
LogD3D12RHI: Found D3D12 adapter 0: NVIDIA GeForce RTX 2060 (Max supported Feature Level 12_1, shader model 6.6)
LogD3D12RHI: Adapter has 5969MB of dedicated video memory, 0MB of dedicated system memory, and 8125MB of shared system memory, 1 output[s]
LogD3D12RHI: Found D3D12 adapter 1: Intel(R) UHD Graphics (Max supported Feature Level 12_1, shader model 6.6)
LogD3D12RHI: Adapter has 128MB of dedicated video memory, 0MB of dedicated system memory, and 8125MB of shared system memory, 0 output[s]
LogD3D12RHI: Found D3D12 adapter 2: Microsoft Basic Render Driver (Max supported Feature Level 12_1, shader model 6.2)
LogD3D12RHI: Adapter has 0MB of dedicated video memory, 0MB of dedicated system memory, and 8125MB of shared system memory, 0 output[s]
LogD3D12RHI: Found D3D12 adapter 3: Intel(R) UHD Graphics (Max supported Feature Level 12_1, shader model 6.6)
LogD3D12RHI: Chosen D3D12 Adapter Id = 0
LogDLSSNGXVulkanRHIPreInit: GetSelectedDynamicRHIModuleName = D3D12RHI
LogDLSSNGXVulkanRHIPreInit: VulkanRHI is not the active DynamicRHI; skipping of pregistering the required NGX DLSS Vulkan device and instance extensions via the VulkanRHIBridge
LogDLSSNGXVulkanRHIPreInit: FNGXVulkanRHIPreInitModule::StartupModule Leave
LogNRD: FNRDModule::StartupModule Enter
LogNRD: Wrapping ScreenSpaceDenoiser with FNRDDenoiser
LogNRD: FNRDModule::StartupModule Leave
LogLinker: AddRedirectList(C:/Users/xxxxxx/AppData/Local/d5_immerse/Saved/Config/Windows/NiagaraFluids.ini) has substring redirect /NiagaraSimulationStages/, these are very slow and should be resolved as soon as possible!
LogStreaming: Display: Async Loading initialized: Event Driven Loader: true, Async Loading Thread: true, Async Post Load: true
[2023.12.08-15.52.03:747][ 0]LogDeviceProfileManager: Applying CVar settings loaded from the selected device profile: [Windows]
[2023.12.08-15.52.03:747][ 0]LogHAL: Display: Platform has ~ 16 GB [17040195584 / 17179869184 / 16], which maps to Larger [LargestMinGB=32, LargerMinGB=12, DefaultMinGB=8, SmallerMinGB=6, SmallestMinGB=0)
[2023.12.08-15.52.03:747][ 0]LogDeviceProfileManager: Going up to parent DeviceProfile []
[2023.12.08-15.52.03:747][ 0]LogMemory: Memory total: Physical=15.9GB (16GB approx)
[2023.12.08-15.52.03:747][ 0]LogMemory: Platform Memory Stats for Windows
[2023.12.08-15.52.03:747][ 0]LogMemory: Process Physical Memory: 118.95 MB used, 119.03 MB peak
[2023.12.08-15.52.03:747][ 0]LogMemory: Process Virtual Memory: 130.97 MB used, 130.97 MB peak
[2023.12.08-15.52.03:747][ 0]LogMemory: Physical Memory: 3374.71 MB used, 12876.08 MB free, 16250.80 MB total
[2023.12.08-15.52.03:747][ 0]LogMemory: Virtual Memory: 6867.91 MB used, 33958.89 MB free, 40826.80 MB total
[2023.12.08-15.52.03:757][ 0]LogWindows: WindowsPlatformFeatures enabled
[2023.12.08-15.52.03:760][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Content/Localization/Engine/zh-Hans-CN/Engine.locres’ could not be opened for reading!
[2023.12.08-15.52.03:760][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Plugins/Online/OnlineSubsystem/Content/Localization/OnlineSubsystem/zh-Hans-CN/OnlineSubsystem.locres’ could not be opened for reading!
[2023.12.08-15.52.03:760][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Plugins/Online/OnlineSubsystemUtils/Content/Localization/OnlineSubsystemUtils/zh-Hans-CN/OnlineSubsystemUtils.locres’ could not be opened for reading!
[2023.12.08-15.52.03:760][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Content/Localization/Engine/zh-CN/Engine.locres’ could not be opened for reading!
[2023.12.08-15.52.03:761][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Plugins/Online/OnlineSubsystem/Content/Localization/OnlineSubsystem/zh-CN/OnlineSubsystem.locres’ could not be opened for reading!
[2023.12.08-15.52.03:761][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Plugins/Online/OnlineSubsystemUtils/Content/Localization/OnlineSubsystemUtils/zh-CN/OnlineSubsystemUtils.locres’ could not be opened for reading!
[2023.12.08-15.52.03:780][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Content/Localization/Engine/zh/Engine.locres’ could not be opened for reading!
[2023.12.08-15.52.03:780][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Plugins/Online/OnlineSubsystem/Content/Localization/OnlineSubsystem/zh/OnlineSubsystem.locres’ could not be opened for reading!
[2023.12.08-15.52.03:780][ 0]LogTextLocalizationResource: LocRes ‘…/…/…/Engine/Plugins/Online/OnlineSubsystemUtils/Content/Localization/OnlineSubsystemUtils/zh/OnlineSubsystemUtils.locres’ could not be opened for reading!
[2023.12.08-15.52.03:797][ 0]LogWindowsTextInputMethodSystem: Available input methods:
[2023.12.08-15.52.03:797][ 0]LogWindowsTextInputMethodSystem: - 中文(简体,中国) - 微软拼音 (TSF IME).
[2023.12.08-15.52.03:797][ 0]LogWindowsTextInputMethodSystem: - 中文(简体,中国) - 搜狗拼音输入法 (TSF IME).
[2023.12.08-15.52.03:797][ 0]LogWindowsTextInputMethodSystem: - 中文(简体,中国) - 搜狗五笔输入法 (TSF IME).
[2023.12.08-15.52.03:798][ 0]LogWindowsTextInputMethodSystem: Activated input method: 中文(简体,中国) - 微软拼音 (TSF IME).
[2023.12.08-15.52.03:812][ 0]LogSlate: New Slate User Created. User Index 0, Is Virtual User: 0
[2023.12.08-15.52.03:812][ 0]LogSlate: Slate User Registered. User Index 0, Is Virtual User: 0
[2023.12.08-15.52.03:834][ 0]LogD3D12RHI: InitD3DDevice: -D3DDebug = off -D3D12GPUValidation = off
[2023.12.08-15.52.03:834][ 0]LogDXGIBridge: calling DXGIBridge::CreateDXGIFactory2 through FDXGIDefaultFunctions
[2023.12.08-15.52.03:834][ 0]LogDXGIBridge: DXGIBridge::FDXGIDefaultFunctions::CreateDXGIFactory2
[2023.12.08-15.52.03:835][ 0]LogD3D12Bridge: calling D3D12Bridge::D3D12CreateDevice via FD3D12DefaultFunctions
[2023.12.08-15.52.03:835][ 0]LogD3D12Bridge: D3D12Bridge::FD3D12DefaultFunctions::D3D12CreateDevice
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device1 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device2 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device3 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device4 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device5 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device6 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: ID3D12Device7 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: D3D12 ray tracing tier 1.0 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: D3D12 ray tracing tier 1.1 is supported.
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: Mesh shader tier 1.0 is supported
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: AtomicInt64OnTypedResource is supported
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: AtomicInt64OnGroupShared is supported
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: AtomicInt64OnDescriptorHeapResource is supported
[2023.12.08-15.52.03:965][ 0]LogD3D12RHI: Shader Model 6.6 atomic64 is supported
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: Device->GetDevice()->CreateCommandQueue(&Desc, IID_PPV_ARGS(OutCommandQueue.GetInitReference())) failed
at D:\d5render_ue5\Engine\Source\Runtime\D3D12RHI\Private\D3D12RHI.cpp:319
with error DXGI_ERROR_DEVICE_REMOVED
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: [GPUBreadCrumb] Last tracked GPU operations:
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: No Valid GPU Breadcrumb data found. Use -gpucrashdebugging to collect GPU progress when debugging GPU crashes.
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: DRED: No breadcrumb head found.
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: DRED: No PageFault data.
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: Memory Info from frame ID -1:
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: Budget: 0.00 MB
[2023.12.08-15.52.04:103][ 0]LogD3D12RHI: Error: Used: 0.00 MB
[2023.12.08-15.52.04:121][ 0]LogD3D12RHI: Error: GPU发生崩溃,或D3D设备已移除。
用-d3ddebug来启用D3D调试设备。
用-gpucrashdebugging来追踪当前GPU状态。
[2023.12.08-15.52.04:143][ 0]LogWindows: Error: Error reentered: Fatal error: [File:Unknown] [Line: 859]
[2023.12.08-15.52.04:331][ 0]LogWindows: FPlatformMisc::RequestExit(0)
[2023.12.08-15.52.04:331][ 0]LogWindows: FPlatformMisc::RequestExitWithStatus(0, 0)
[2023.12.08-15.52.04:331][ 0]LogCore: Engine exit requested (reason: Win RequestExit)
[2023.12.08-15.52.04:331][ 0]LogWindows: FPlatformMisc::RequestExit(1)
[2023.12.08-15.52.04:331][ 0]LogWindows: FPlatformMisc::RequestExitWithStatus(1, 3)
[2023.12.08-15.52.04:331][ 0]LogCore: Engine exit requested (reason: Win RequestExit; note: exit was already requested)
[2023.12.08-15.52.04:335][ 0]Log file closed, 12/08/23 23:52:04
