SU实时连接插件报错
在一次报错以后,实时连接插件无法使用,并且每次开启SU都会弹出报错弹窗
载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb 时出错
Error: #<JSON::ParserError: 783: unexpected token at ‘’>
E:/SU/SU22-2/Tools/RubyStdLib/json/common.rb:156:in parse' E:/SU/SU22-2/Tools/RubyStdLib/json/common.rb:156:in parse’
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:164:in load_d5_config_item' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:2005:in init’
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:2042:in <module:D5Main>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/su_to_d5render/su_to_d5render.rb:1923:in <top (required)>’
E:/SU/SU22-2/Tools/extensions.rb:197:in require' E:/SU/SU22-2/Tools/extensions.rb:197:in load’
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/d5_converter.rb:58:in register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/d5_converter.rb:58:in module:D5Converter
C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2022/SketchUp/Plugins/d5_converter.rb:29:in `<top (required)>’
您好,请截图看下具体报错弹窗
如果是此种报错,请到目录:C:\Users\Administrator\AppData\Roaming\SketchUp\SketchUp 2022\SketchUp\Plugins\su_to_d5render 下找到D5LiveSync.conf 文件删除后重启SU,看是否正常。
28e00de513b866ffe6ea8d86973571cd
